Marked 2 holes on centerline at 3 1/2 inches apart-same distance as holes in gear support angles. Drilled 2- #40 holes in gear on drill press and drilled corresponding holes in gear angles. Used two 3/32 pins to align gear to fuselage. Checked to be sure gear was perpendicular to longitudinal axis of fuselage. Updrilled forward centerline hole through gear and fuselage to 1/4 " and installed temporary fastener to hold in place. Checked again for square and updrilled second hole to 1/4 inch and installed one more temporary fastener. Checked again for square and updrilled remaining 8 holes to 1/8". Now that all gear pilot holes are drilled it will be easy ti install the gear.
