Lorens Web Site
Date:  12-28-2011
Number of Hours:  8.00
Brief Description:  Continued Fuselage Assembly
Established centerline on work table and set up tight wire to check alignment. Aligned bottom centerline of aft fuselage with tight wire and hung mercury plumb bob from center of top cross ties to insure box was square. Did not have to make any adjustments so the Sonex supplied parts were very accurate. I just wanted to check to be sure before starting any riveting
Aft fuselage checked
Forward cross tie on aft fuselage checked
Work table level and aft fuselage level
