Brief Description: Left Hand Outboard Forward Fold Rib Assembly
Updrilled doubler plate to left hand rib position 6 and countersunk doubler plate. Took some time to get the microstop set up for the correct depth. Deburred all components and riveted with CCC 42 and CCC44 rivets.
Had a hole drilled in a piece of MDF for drilling the countersinks and connected vacuum to bottom of drill press table. This sucked all of the shavings out of the way so I didn't have to shake the shavings out of my way.
