Brief Description: Center Rear Main Spar Assembly and Outboard Rear S
Made extension for stand to support components being drilled in drill press. Assembled center rear main spar on right side only. Left side will have to be left unassembled until after spar is inserted through fuselage. Also assembled both outboard spars
