N983LK
Date:  6-17-2020
Number of Hours:  3.00
Brief Description:  Starter contactor and Tach wiring
Soldered a resistor in line in the starter annunciator power wire per the VPX-pro instructions.
Terminated the starter annunciator and contractor energize wires with ring terninals and connected the ring terminals to the contactor. Zip tied the wires to the main power wire.
Soldered resistor to short lengths of 20 gauge wire and connected them to the LH and RH mag P-leads at the spade terminal for connecting the P-leads to the mag switches. This required cutting off the ring terminal that was previously crimped on the end of the P-lead and crimping on a larger ring terminal on that combined the respective LH and RH P-leads and RPM sense wires. Solder spliced the wires from the resistors the the RPM wires from the SV-EMS. String tied the P-Leads and RPM wires to the existing wire bundles.
Resistor in series in starter annunciator
Starter contactor energize and annuciator wiring
RPM wires on P-leads
Copyright © 2001-2021 Matronics. All Rights Reserved.
