N983LK
Date:  6-27-2018
Number of Hours:  3.00
Brief Description:  More wiring
Started hooking up wires to the VP-X routed pre-terminated wires, that were included with the VP-X Pro wire kit, from the VP-X, through the RH gear tower and to the back-up switches on the lower switch panel. Routed the power wires from the back up switches to com 1 (the IFD-440) and the boost pump. Ran the front USB outlet power wire from the VP-X pro to the USB outlet and ran the USB outlet ground wire from the outlet to the firewall where the forrest of tabs grounding point will be. Labled all wires.
Copyright © 2001-2021 Matronics. All Rights Reserved.
