Cut a 20 gauge black wire to length to run from the SV-COM-425 to the avionics bay ground block, installed labels and terminated one end with a D-sub receptacle. Routed the wire to the ground block area.
Installed the D-sub connector backshell on the connector and installed the harness on the SV-COM-425. Tied the harness with string ties
