N983LK
Date:  3-10-2018
Number of Hours:  4.50
Brief Description:  Wiring
Remounted nav/strobe terminal strip so it is oriented vertically vs horizontally to simplify the wire routing. Trimmed the tail nav/strobe to length, installed a solder sleeve with wire pigtail for grounding the wire shield and terminated the three conductors and the ground pigtail. Connected them to the terminal block.
Worked out wire routings and installed Adel clamps to hold the bundles in place.
Prepped, painted and baked the lower switch panel.
Spent a lot of time tying to figure out how to rout the wires from the wings and whether to use connectors.
Terminal strip for Nav/Strobe lights
Adel clamps for wire bundles
Copyright © 2001-2021 Matronics. All Rights Reserved.
