N983LK
Date:  2-24-2018
Number of Hours:  6.00
Brief Description:  Misc work
Painted the lower switch panel but dropped it in the paint booth and marked up the paint. It will have to be sanded and repainted.
Sanded an repainted the mid-cabin brace covers and then baked them. They look a little more green than the rest of the interior. It could be because it has too coats of paint. I may have to strip the paint and redo it.
Removed the paint from the spot on the bottom of the LH canopy rail for a click stud to hold an adel clamp for the headset wires. Solvent wiped it, applied adhesive to the click stud, positioned it in place under the LH canpoy rail, stuck the applicator to the rail and clicked it to hold the stud in place. After a couple of hours I removed the applicator and attached an adel clamp.
Installed sprial wrap around the headset wiring.
Installed expanding sleeving over the front stick grip wiring in the area where it will enter the stick. Used shrink tube to hold it in place. Installed the stick grip on the front stick.
Temporary mounted the front stick in the aircraft.
Click stud and adel clamp
Front stick grip
Front stick grip
Stick in place
Stick in place
Copyright © 2001-2021 Matronics. All Rights Reserved.
