N983LK
Date:  8-18-2017
Number of Hours:  6.00
Brief Description:  ELT antenna bracket and E-Bus wiring
Completed the ELT antenna mounting bracket. Match drilled the aft flange of the bracket and the F807 bulkhead. Dimpled, scuffed, cleaned and primed the bracket. Installed the nut plates and bolted the bracket in place.
Drilled a hole through the F807 bulkhead for a snap bushing through which I'll route the wires for the E-bus. Started routing the E-Bus wires.
Completed ELT antenna bracket
Copyright © 2001-2021 Matronics. All Rights Reserved.
