Brief Description: Static line supports and transponder antenna
Drilled holes for adel clamp standoffs to support the static line on the F809 bulkhead. The plans call for zip tieing it directly to the bulkhead but I'm not a fan of zipties, plus the static lines didn't have a straight shot to the fittings which could potentially cause a leak. Supporting the static lines with adel clamps keeps the line from contacting any airframe parts and makes for a straighter shot into the fitting. The standoffs will not be riveted in place until after the upper skin is riveted on.
Made a doubler (actually I made five until I was satisfied with it) for the transponder antenna mount location. Drilled holes to mount the antenna to the lower skin. Drilled and dimpled rivet holes in the doubler and skin
