Brief Description: Fuel flow sensor wiring and alternator field wire
Terminated the wires from the fuel flow sensor with D-sub pins. Terminated the fuel flow wires from the SV-EMS with D-sub sockets. Connected the pins/sockets. These will eventually have shrink tubing over them to secure the connectors together.
Solder spliced the alternator field wire from the alternator connector and the field wire from the voltage regulator. Covered the splice with shrink tubing and string tied the field wire to the B-lead
