Installed the sniffle valve in the bottom of the engine sump. Bent an aluminum tube to match the angle of the exhaust and connected it to the sniffle valve with a short piece of rubber hose. Installed hose clamps on both ends of the hose. Fabicated a zee from 4130 steel and secured it to the exhaust collector with a hose clamp. Bolted an Adel clamp to the zee to secure the aft end of the sniffle valve outlet tube.
