N983LK
Date:  11-8-2020
Number of Hours:  2.50
Brief Description:  Wheel Fairings part 1
Started the wheel fairings. Sanded the forward half of the LH wheel fairing so that it fits tightly together with the aft half. Drilled #40 holes through both forward and aft halves at the locations shown on the plans and clecoed the halves together. Drew a centerline on the top of the assembled fairing and marked the cut lines on the bottom what will give 1/2 inch clearance from the tire. Reinstalled the axels, brakes and tires and taped a 1 inch spacer block to the top of the tire to provide the required spacing between the wheel fairing and the tire. Deburred the U-808 outboard bracket and bolted it to the LH side axel nut.
LH wheel pant halves clecoed together
Spacer block and U-808 bracket
