Added some Super Fill to the aft end of the canopy skirt to add some shape to the tunnel to make it symmetrical from left to right.
Used an epoxy/micro/cabosil mixture tinted black to form a fillet where the windscreen contacts the forward upper skin
Bonded a click bond wire tie base to the aft end of the WD-807 Control column. This will be used to secure a short piece of Velcro that will hold the wire harness from the aft stick. I'm using Velcro so that I can remove the harness without any tools
Black tinted micro
Windscreen filet
Click bond base for anchoring wire bundle from rear stick
