Brief Description: Cabin heat and alternate air bracket paint and lab
Sanded the micro on the wing tips. Removed the tape from edges of the wing tip lenses and checked the fit. Reapplied micro to the LH wing tip on one edge.
Baked the primer on the cabin heat and alternate air door cable brackets. Wet sanded, painted and baked the brackets
Applied dry transfer labels to cabin heat and alternate air door cable brackets and the ELT access door. Sprayed 6+ coats of clear satin to seal the dry transfers.
Primed and painted the bracket for the current shunt and ANR fuse
