Installed the LH axle, brake caliper, wheel spacers, wheel and wheel nut in place. Installed one of the flexible brakelines from the bottom of the gear leg to the caliper but found that it was too long. Contacted Tom at TS Flightlines. It turned out that the ones I had were 1 1/2 inches too long so he's going to send me two replacements.
Installed the RH axle, brake caliper, wheel spacers, wheel and wheel nut in place.
Match drilled through the axels nuts and through the axels for the cotter pins. Installed the cotter pins
