Painted and baked the access doors for the battery and ELT.
Removed the forward top skin to gain access for installing the B&C voltage regulator.
Removed and disassembled the rudder pedal assembly in preparation for painting.
Drilled mounting holes in the rudder pedals and mounted the ML Skunk Works rudder pedal extensions that I opted to use. With the stock rudder pedals people have had problems inadvertently applying the brakes because it can be hard to tell which part of the pedals your feet are touching. These extensions allow your feet to contact just the bottom of the pedals when applying rudder.
