Fabricated doublers for the battery access door cutout. The doublers will extend inside the cutout area to provide a lip for the access door to sit on. The doublers also have built in flanges to help stiffen the baggage shelf.
Cut the hinge to size. Drilled holes for mounting the doubler and hinge.
Painted and baked the rear cabin side panels as well as a test panel to experiment with dry transfer graphics and clear coats
