Drilled for nut plates at the hole locations where the Adel clamps for the #2 GA starter cable and main aft avionics bay wire bundle are fastened to the aft baggage floor supports. Riveted nut plates in place.
Drilled the LH lower aft longeron for rivets to attach a standoff. Rivet the standoff in place This will be used for securing the three conductor wire for the flap position sensor.
