N983LK
Date:  6-17-2017
Number of Hours:  6.00
Brief Description:  Started a mount for the aft skyview hub and ADS-B
Scuffed, cleaned and primed the IML side of the antenna doublers and step hole cover plate. Removed the primer from the IML side of the fuselage skin where the two antenna doublers will go. The primer was removed to ensure a good electrical bond for the antenna ground plane.
Began fabrication of sidewall mount for the aft Skyview hub and ADS-B receiver
Primer removed for antenna doubler
Building up the mount for the aft hub and ADS-B RX
