Brief Description: Completed installing VS and installed elevators
Trimmed the VS front spar to leave 2D edge dimension below the bottom line of rivets (the instructions called for removing 9/16 of an inch before fitting the VS to the fuselage but I had read on other builders sites that 9/16 leaves the ED short, so I trimmed as necessary which was well less than 9/16"
Riveted the VS forward attach plate as spacer to the VS front spar. Bolted the elevators in place
