Brief Description: Drilled mounting holes for vertical stabilizer
Finished squaring the VS to the HS. Clamped it in place and drilled the holes common to the bottom of the VS rear spar, the fuselage aft bulkhead and the tailwheel fitting.
Drilled the two holes common the the VS aft spar and the bracket at the top of the aft deck.
Aligned the front of the VS so its centerline is on the fuselage center line and the three rudder hinge brackets are in line. Clamped it in place and drilled the 11 #30 holes in the forward attach bracket.
Opened upto #12 the four holes that hold the VS foward attach splice plate to the HS forward spar.
Removed the VS from the fuselage. Deburred all holes. Scuffed, cleaned and primed the splce plate the spacer.
