Brief Description: RH fuselage rail riveting and started on battery t
Riveted the RH cockpit rail in place
Clecoed the seatback support plates in place.
Clecoed the bulkhead caps in place. They won't get riveted yet.
Painted the exposed heads of the flush rivets through the cockpit rails. To get liquid paint I sprayed paint from the rattle can into a plastic cup. I used a cheap hobby paint brush (a couple of bucks for a couple dozen) to paint them.
Deburred the parts for the aft battery tray. I will most likely go with the aft battery option to keep the center of gravity as far aft as possible since I'll be using a constant speed (heavy) prop.
Both cockpit rails riveted in place and seatback supports clecoed in place
