Brief Description: Baggage rail bulkhead and rear seatbelt brackets
Installed the rear baggage rail bulkhead hut had to first countersink for flush rivets. The plans called out universal AN3 rivets but none came with the kit. Plus the rivets on the top need to be flush because of the pitch servo bracket that will mount to the top of the baggage rails.
Riveted the rear seatbelt bracket support angles to the sides skin and installed the rear seatbelt brackets. Installed the bolts, washers and nuts and torqued the nuts to spec.
