Brief Description: More mid-section side skin assembly prep
Deburred the long outer floor attach angles. Matching counter sunk the nut plate rivet holes in the outer floor attach angles and the center mid-section side bulkheads and dimpled the nut plate attach holes in the arm rests.
Removed strips of vinyl over the holes on the OML sides of the mid-section side skins. Removed all vinyl from the IML
