Brief Description: Fuselage center section continued
Match drilled center section ribs to bulkhead. Clecoed the center section bottom skins and match drilled the skins to the center section ribs. Disassembled the center section.
Scuffed, cleaned and primed the part for the center section aft bulkhead. Riveted those parts together.
Scuffed, cleaned and primed the parts for the seatbelt lugs and the top angles.
