Brief Description: Riveting firewall to floor and started assembling
Applied firewall sealant to the faying surfaces between the center of the forward edge of the forward floor and the bottom firewall angle. Riveted the firewall to the forward floor except for the nine holes in the center which will be riveted in a later step.
Installed 12 1/4 inch bolts in the forward center section bulkhead. Riveted the center section vertical bulkheads to the forward bulkhead.
