Disassembled and deburred the landing gear box towers components.
Modified the landing gear tower box webs to provide improved access for systems installation and maintenance. This is a popular mod done by many builders. First I cut the web out between the two middle lightning holes to make one large hole. I then fabricated cover plates, match drilled the plates and webs for #8 screws and drilled the webs for nutplates. This doesn't sound like much but it took about 6 hours.
Drilling the #8 screw holes to attach the cover plate
Removing the web between the two middle lightning holes
