Brief Description: Wing tips part 13 and some canopy work
Sanded the micro on the RH wing tip with 80 grit.
Sanded the LH wing tip and applied more dry micro to both sides
Trimmed the forward upper corner of the canopy skirt for clearance from the canopy bubble forward reinforcement strip.
Applied some spot putty (from AutoZone) on some low spots on the micro on the bottom surface of the RH wing tip. I had resisted using spot putty since it is polyester and the micro is mixed with epoxy. I had wanted to use micro for everything but the spot putty spreads better and dries faster.
Received the replacement wing tip lenses that I had ordered and started covering them with masking tape to prevent scratches during the trimming process.
Trimmed canopy skirt to clear the front reinforcement strip
