Brief Description: RH wing tip attach hinges and STARTED FUSELAGE!
Snomagedon 2016! Good day to stay in side and work on the plane.
Cut RH wing tip rib to fit between attach hinges. Riveted inboard halves of RH wing tip attach hinges to the RH wing. I’m declaring the wings done for now. I'll finish up the wingtips later when the weather is warmer and I can open the garage doors while doing the fiberglass work.
Started the fuselage by starting deburring the firewall reinforcement angles.
