Laid out and drilled the hole locations for the row of rivets that will attach the inboard half of the RH wing tip bottom attach hinge.
Cut the RH wing tip top attach hinge. Clamped it in place on the wing tip and match drilled the outboard row of rivet holes. Laid out and drilled the hole locations for the top inboard hinge half.
