Laid out the holes to attach the LH wing tip closeout rib. Drilled holes for the wingtip close out rivets.
Sanded the edges of the flanges on the RH wing tip so that it fit correctly on the wing with the wing skins edges next to the flange joggle.
Positioned the RH wing tip on the wing, taped it in place and used the laser level to align the trailing edge with the aileron. Match drilled the holes through the wing skins into the wing tips.
Cut the bottom attach hinge for the RH wing tip to length, clamped it in place on inside the wing tip and match drilled the holes in the wing tip through the wide hinge half.
Laying out the rivet holes for the LH wing tip closeout rib
LH wing tip closeout rib clecoed in place
Match drilling the RH wing tip for the bottom attach hinge.
