Brief Description: LH Wing tip top inboard hinge half
Countersank the hinge spacer (which was the wing tip flange before it was cut off). Dimpled the holes in the top of wing skin for the inboard hinge half. Riveted the hinge in place except for the bottom two because they also hold the hinge piece that will push on the outboard hinge half to keep it tight against the in board half to remove free play in the tip attachment. Those two rivets will be installed after one more fit check of the wing tip to make sure they are tight.
