Brief Description: Started building the pitot controller harness
Cut three 15 foot strands of wire for the harness that will run from the pitot heat controller to the fuselage. Two are 14 AWG and one is 18 AWG. A 15 foot harness will leave about 10 feet sticking out from the wing root which should be plenty.
Cut an 8 inch length of braided sleeving and two short pieces of shrink tubing. The sleeve will be on the outboard end of the harness where it runs past the aileron bellcrank.
Experimented with installing one of the molex connectors on one of the wires.
