N983LK
Date:  11-11-2015
Number of Hours:  3.50
Brief Description:  More pitot tube and wiring routing
Finished the pitot/AOA tube wiring and tubing support angle. Primed and installed nutplates. Drilled mounting holes in rib for support angle
Drilled holes in the tubing support bracket that bolts on with the bellcrank bracket bolts. One of the holes is for an Adel clamp to support the wiring from the pitot heat controller and the other is for a snap bushing through which the pitot heat wire harness from the fuselage will run.
Installed braided sleeving on the wire harness from the controller to the connectors for the pitot
Tubing and wire harness support bracket
Added holes to tubing/wire support bracket on bellcrank
