Cut the spacers for the LH aileron attach bolts. Temporarily installed the bolts, spacers, washers, rod ends and nuts for the LH aileron per the plans.
Cut a nylon bushing to fit over the aluminum spacer on the control rod attach bolt. The bushing will serve as a stop for the aileron.
