Finished drilling the long pushrods. Taped one end of each long pushrod tube and poured liquid primer in the tubes. Taped off the other ends and then let the tubes sit on a roughly 45 degree angle for a couple of hours flipping and rotating them periodically to spread the prmer out.
Removed the tape from the long tubes and hung them vertically with one end in a plastic cup to let the primer drain.
Riveted the threaded rod ends to the short pushrod tubes.
Pushrod priming
Drying primer inside long pushrods
Threaded rod ends riveted to short aileron pushrods
