Deburred, scuffed, cleaned, dimpled and primed aileron skins.
Back riveted the aileron stiffeners to the aileron skins.
Bent the aileron skin trailing edges using the bending brake I made for the empenage parts to get them partially bent and then I made the final bends with a pair of water pump pliers and wood shims to protect the aluminum skin
Started match drilling aileron spar ends with reinforcement plates, attach brackets and nose rib
