Brief Description: Started riveting wing skins and misc deburring
Edge deburred the aileron and flap braces
Installed the rivets on the LH inboard top skins. Lynn held the back riveting bucking bar on the OML of the skin and I back riveted from the inside using a long straight back rivet set. It worked great and all of the rivets were of good quality except for the a few early ones which weren't quite flush. They'll have to get drilled out.
I then used the rivet squeezer to install the skin to aft spar and skin to inboard rib rivets.
