Brief Description: Fabricated another bucking bar guide
Fabricated a second bucking bar guide from wood. This one is cut to fit the second and third most outboard ribs and it is long enough to go from skin to skin so it is self-centering. I may remake the one I made for the second and third most inboard ribs since it is not as wide and can be installed off center.
Torqued and torque striped the tie down bracket mounting bolts in the RH wing.
