Received the offset and long straight rivet sets. Ground a flat in the single offset. Then drove some more rivets with the singe offset. For the second most outboard rib I had my wife hold the bucking bar on the inside of the leading edge. She caught on quick and the rivets look good except for the one I overdrove and the one I screwed up the head on. The center rib is the only one remaining on the LH leading edge and I'll need someone with longer arms than Lynn. My sone is coming over Friday night to help.
I'll also need to drill out a few of the rivets but I ordered a rivet removal tool so I'll wait for that since it should be less likely to result it deformed holes.
