Fabricated small aluminum strips. Two with a 1/4 inch radius at one end to two flat. Covered them with teflon tape. I then applied some proseal to the top and bottom aft corners of the RH tank IB rib and clamped the strips in place. The idea is to form proseal radii in the cornes to seal that area up since they are a common leak point.
Cleaned and applied proseal to the AN elbow fittng that passes through the RH tank acces plate for the fuel pick up torqued the nut and smoothed the proseal.
