Brief Description: Tank rib dimpling and cap flange riveting
Bent the vent tube for the RH tank. Dimpled the tank ribs and clecoed the center five ribs to the tank skins. practiced assy sequence for when proseal is applied to ribs and skins. Removed clecos one at a time from cap flanges and cleaned cured proseal from rivet holes. Replaced each cleco before moving to the next.
Riveted the cap flanges by wet installing the rivets and driving them with a rivet gun with mushroom set on the OML skin and my tungsten bucking bar on the inside.
Finished the night by applying a dab of proseal on each of the cap flange rivets with a toothpick.
