Brief Description: Fuel caps contiuned and fuel drains
Opened up the hole in the LH skin for deluxe fuel caps. Match drilled the holes common to the fuel cap flanges and tank skins. Machine countersank the fuel tank flanges. Scuffed, cleaned and dimpled (with tank dimple dies) the fuel cap flange attach holes in the tank skins. Centered the fuel drain fittings on the predrilled holes in the tank skins and Match drilled the holes in the drain fitting flanges through the tank skins
