N983LK
Date:  4-26-2015
Number of Hours:  5.00
Brief Description:  T-405 tank attach angles
Fabricated the T-405 tank attach angles. Copied and pasted the flat pattern of the angle flange shapes into Visio and enlarged them to full scale. Printed out the shapes and cut them out to make paper patterns to draw the angle shapes on the raw angle stock. Rough cut the angle shapes with a band saw and then used a disk sander, a variety of files, and an angle grinder with a scotch bite wheel to smooth out the edges.
Rough cutting angle
Rough cutting angle
Paper pattern for rib attach  flange
Finished angles
Finished angles
