Took the day off from work and got a full day of work in on the airplane. Countersank landing light lens for mounting screws. Prepped and primed lens retainer strips. Drilled outboard ribs for landing light reflector mounting nutplates. Reclecoed RH leading assembly and matched drilled skin to ribs and skin to spar. Deburred tank splice plate, drilled holes for nutplates and dimpled all holes. Modified ribs to cut out the gaps between the flange tabs that were causing a bump in the skin OML. Deburred holes in rib flanges. Scuffed ribs, splice plate and landing light reflector for paint.
