Used a laser level to double check the marked location of the cutout for the Duckworks landing light in the RH leading edge. When I was satisfied with the location I drilled holes in each of the corners with the unibit and then used a dremel tool to cut the opening within ~1/4 of the final size followed but a 1/2" sanding drum to sand it to final size
