Build leading edge cradle Deburred, edges of LH leading edge ribs. Straightened and fluted flanges in LH ribs.
Cut hole for stall warning tab in LE.
Clecoed ribs to LH LE skin. Installed Placed LE assy on spar and fit LE inboard rib in place. Back drilled holes through spar into (undrilled) inboard LE rib. Started to fitup splice plate but discovered that the inboard rib was shifted abot 1/8 inch toward the top skin which would result in a bulge in the top kin and a concavitiy in the bottom skin. Time to order a new rib pay better attension to centering it when back drilling the flange
