Brief Description: Started to assemble LH elevator substructure
Assembled LH elevator outboard rib. Partially installed rib to spar but had difficulty setting two rivets and ended up oversizing one of the rivet holes when drilling out the rivet. Drilled the hole to number 21 and ordered 5/32 rivets, and rivet sets.
